Пользователь №: 8980
proteus
Added: - PIC18K series. - PIC16F91X models - PICDEM MC (mechatronics) virtual evaluation board - ATTiny 13 model - AT2FXXXX and M45PEXX serial flash memories. - INA117 high common mode voltage differance amp. - LM134/234/334 adjustable current sources - IR2101/IR2102 high and low side mosfet drivers. - TL783 regulator. - LM34/LM35/LM45/LM50 temperature sensors. - AD693 sensor transmitter. - Improved hit-testing logic for labels, wires and pin ends in ISIS. - Improved DC and transient convergence and convergence diagnostics in PROSPICE. - Clipboard commands (cut/copy/paste) to the edit menu in ARES. - Display of component rotation on status bar in ARES. - Universal LCD Panel model + specific 3 1/2 and 4 digit displays - LT1030 and LT1030-5 regulator models
Fixed: - Rotate whilst place/drag can move pins/pads off grid (ISIS/ARES) - Graphs not printing in colour (ISIS) - Print preview not updated when colour checkbox is clicked (ISIS/ARES). - Problem in translation of SPICE2 POLY sources where coefficents are zero (PROSPICE). - Data corruption where components with embedded tracks are copied through the clipboard. (ARES) - Polygon merge problems and crashes where there are coincident points in the groundplane boundary. (ARES) - Erratic behaviour when clicking right - second click is sometimes missed - (ARES) - DRC is regenerated when disabled after undo (ARES). - Deleting manually entered ratsnest lines produces corrupt net names (ARES). - Orientation bar restricts angle to orthogonal only (ARES). - UAE when selecting padstack mode after re-loading layout (ARES). - Various issues related to keyboard mapping. - Problem with DOUT in MAX7219 model - Oscillscope and Logic analyser cause graph based simulation to fail. - UAE when writing CNEN2 register of PIC24. - Zero SRAM size in ATMEGA 64. - Wrong part description of 74141. - Installer hangs on some X64 systems. - UAEs with keyboard short-cuts in the MPLAB viewer. - Various deadlocks between ISIS and the MPLAB resulting in 'server busy' dialog. - Strange behaviour with the mouse focus when closing graph windows and/or the 3D viewer. - Licencing issue with DVCO.DLL
Это сообщение отредактировал avr123 - Jun 11 2009, 04:21 PM
PROTEUS не печатает время/деление на распечатке экрана осциллографа, хотя по каждому сигналу пишет масштаб вольт/деление и смещение сигнала по вертикали в вольтах и вид развязки DC, AC входа. Так что не забывайте сами указвать масштаб времени, например в названии файла осциллограммы - а то потом не вспомните.
