Hi friends, "ruslan" and "R2-D2" , I am still install and try some parts, my oscillator about up to 900khz (author says 700-800khz good area)and jump drift up and down, I try to all 113 page read again in google translate then I am found if C1 and L1 not good then this happens mostly and I am buy and try some inductance and good capacitance later, also somehow my 50ma source sometimes jump and drift a little bit 49.7 +-0.2ma. I was made a mistake in layout drawing relay driver pins because in schematic relay pin names not same in PK-5 datasheet and I accept relay pin sides as exactly in schematic then I draw for TQ2Sa-L2-5V , I swap driver transistors to relay drive legs and fix the problem (I am reversed relays set and reset conditions).
When I read all pages from to start I see this message from author
page 76 authors message "# 389766 "
and if I am understand correctly (~ 6.0) value in description pdf actually amps gain values but no any explanation to how can we properly measure or calculate these values. In my pictures (I also find random online opamp gain calculator and calculate my values) first opamp c_adc, second r_adc,
1- Can we calculate (in red area in the picture) or measure(with series input output 1k resistors) to gain then write in setup menu?
2- and these measurements or calculations
for amp1=point "D" to "E" (looks easy understanable) (in my examle gain=6)
for amp2=point "D" to "F" (2 amp gain serial in my examle gain=12) or "E" to "F" (only amp2 gain in my examle gain=6)
I ask because two gain stages become a serial, so is the "measurement point to r_adc" author says in message, this means 2 opamp serial gain calculation, am I right? or just only amp2 gain must be set and write in setup?
If we adjust R3 and R8 screen readings change and also we adjust amp1 amp2 in menu also change, not easy to catch correct gain stage and write in menu I guess. Sorry for my poor English.
